QUOTE(914 7T3 @ Jan 18 2018, 07:48 PM)
QUOTE(oldie914 @ Jan 18 2018, 12:17 PM)
I agree with Dr Evil.
Looks like silicone sealer which builds up the gasket thickness. The gasket under the intermediate plate determines the pinion depth. Using silicone sealer increases the gasket thickness which negates the depth adjustment done without sealer.
You should only use sealer that soaks into the gasket. I use Locktite 574 or similar.
Product used here is Three Bond silicone liquid gasket for engines and gearboxes. Product dries flat and does not affect pinion depth.
Still not necessary, not recommended in the factory manual, and I don't use any.
Dimensionless sealant? Reminds me of the time long ago when I was putting some roll on sound deadener in my car and a guy said it would add 400#...the bucket, mixed, was 40#. Magic
I will add this, though, the spec is +/- 0.03mm and the used ring and pinions are not as tight as 40 yrs ago (hey, none of us are). They tolerate a lot of slop in setting, I have seen it/done it in the beginning. However, correct is still correct and sealant is an attempt at improving on something that does not need it. Leaks happen from the rubber seals 99% of the time. If it leaks from the paper, that's a bad sign and a case needing truing.
