Will be trying to start a '70 914-4 (Webers) that hasn't run in 7 years. Plan to do the following:
New battery
Check the oil level
Want to avoid pulling the plugs so I'll shift the carbs off the manifolds and pour a quarter cup of Marvel Mystery Oil into each intake, put the carbs back on.
Crank it over with the coil wire off until I get oil pressure
Put a little gas in each carb throat and see it it fires
If it fires I'll put some fresh gas in the newly sealed tank and see if it will run...
What am I missing?
Thanks for your advice in advance.
