rfinegan
Jan 19 2018, 09:13 AM
I need to find a shop that can work and repair a 2.0 Djet.. I recently installed the system back on my 75 914 2.0l It had weber a carb conversion . It runs well at High way speeds but at idle and off idle it has a stumble /miss. At idle it is sometimes good but often gets rough and surges
Cold start is fine for the first 30 sec to a min then it will start stumbling and missing off idle. IT runs better when warmer and seems to idle best once coming off a hi way cruise
=Robert
Jan 19 2018, 09:23 AM
www.blackforestracing.com
The owner, John Forbes, is an avid 914 enthusiast.
rfinegan
Jan 19 2018, 09:34 AM
Yep, Was thinking about giving him a call...3 hr drive
QUOTE(mepstein @ Jan 19 2018, 07:23 AM)
Jan 19 2018, 10:04 AM
Worth the drive.
QUOTE(rfinegan @ Jan 19 2018, 10:34 AM)
ranger
Jan 19 2018, 02:17 PM
Check out Chuck Miller at Miller Sports 306 Rabbit ln. Hillsbough NC. 27278
(919) 644-2930...I'm sure he can help,,,
DRPHIL914
Jan 19 2018, 02:21 PM
QUOTE(rfinegan @ Jan 19 2018, 10:13 AM)
=Robert
vacuum leak suspected, or lean running, could be bad MPS developing too.
thelogo
Jan 19 2018, 03:16 PM
Djet specialists
You guys crack me up around here
Dave_Darling
Jan 19 2018, 04:26 PM
Go to this website, and read read read read READ! You will likely wind up knowing as much or more than anyone at the aforementioned shops...
http://members.rennlist.com/pbanders--DD
Mblizzard
Jan 19 2018, 04:35 PM
Also would suspect TPS sensor board of there are no vacuum leaks and the MPS is good.
era vulgaris
Jan 19 2018, 04:43 PM
If you can make the 3 hour drive, I'd take it to Black Forest Racing. I've been down there with both of my 914's and they know these cars probably better than any other shop in NC.
There's also Road Scholars in Durham, but they are $$$$$. I've never been been there so I can't say how well they know their stuff. They quoted me $1600 to replace an RMS on my old '75, so I said thanks but no thanks!
