Kerrys914
Jul 9 2003, 08:58 AM
I need to buy new bulbs all around for my '74. Does anyone have a list of bulb types and the qty of each handy?
Cheers
Kerry getting close
JeffBowlsby
Jul 9 2003, 09:27 AM
I have started one awhile back...its not complete or guranteed accurate...use at your own risk. Lessee if it pastes in with proper tab delimits:
1974 Porsche 914 Lamp Index
Number Volts Watts Filament Lamp
H-4 55/60 dual Euro Headlamp (halogen)
6014 60/50 dual USA Headlamp (sealed tungsten)
H-3 55 single Euro foglamp
35 single USA foglamp
1157 12 21/5 dual USA Front turn signal/parking (front turn signal housing)
1895 12 4 single USA Front side marker
High beam indicator (bottom of tachometer)
Turn signal indicator (top of tachometer)
Parking lamps indicator (bottom of speedometer)
Tachometer illumination (2)
Speedometer illumination (2)
12 1.2 single Seatbelt indicator
12 1.2 single Heater control assembly illumination (3)
12 1.2 single Fresh air blower indicator
Alternator charge indicator (combo gauge)
Low fuel warning (combo gauge)
Oil pressure indicator (combo gauge)
Parking brake warning indicator (combo gauge)
Fuel gauge illumination (combo gauge)
Clock illumination (center console)
Oil temperature illumination (center console)
Voltmeter illumination (center console)
12 1.2 single Defroster lever illumination (center console)
12 1.2 single Fog lamp indicator (under dash switch bezel)
12 1.2 single Hazard flasher indicator (under dash switch bezel)
12 10 single Interior cabin (backpad)
12 4 single Rear luggage/engine bay (or is it 10W?)
1157 12 21/5 dual Stop/rear (taillight housing-parking taillight-brake)(1034?)
7506 12 21 single Rear turn signal (taillight housing) (1073?)
1816 12 5 single USA rear side marker (taillight housing)
15607 12 10 single Rear license plate (2)
12 21 single Rear back-up (Phillips-12498, 15894 – 1816 or 1891?)
JeffBowlsby
Jul 9 2003, 09:28 AM
Nope...not gonna do it...send me your email address and I will email it to you as an attachment.
Kerrys914
Jul 9 2003, 01:25 PM
Just to clarify..
I am replacing the;
- interior light
- All the lights in the rear tail light assembly
- The bulbs in the front
- Light in th eengine bay
- Light in the trunk
Also I have euro lense if it makes a diff in the rear lights
Cheers
Kerry
Demick
Jul 9 2003, 01:47 PM
From an old Automotion catalog. You should be able to cross reference the part numbers to whatever brand your FLAPS carries.
Automotion used to sell a bulb kit with all of the bulbs needed for the car - 16 bulbs total for $15. Not sure if Performance Products now sells the same thing.
Parking Light: LB-7382
Front Turn Signal: LB-7382
Front Side Marker: LB-7172
Tail Light: LB-7382
Stop Light: LB-7382
Rear Turn Signal: LB-7322
Rear Side Marker: LB-7172
License Plate 70-74: LB-7172
License Plate 75-76: LB-7182
Back Up Light: LB-7102
Interior: LB-7232
Instrument/Indicator: LB-7222
Luggage: LB-7172
Pull Switches, Heater Control, Seat Belt: LB-7228
Demick
'74 2.0
