BCinSC
May 31 2005, 08:28 AM
Is there a way to check voltage regulator on the bench with multi-meter? Is there a particular Ohm reading or something that might suggest it's good or bad? Is there a better replacement choice than OEM?
wilchek
May 31 2005, 10:15 AM
if it is in the car it should but out abour 13.9 volts at the battery. If you are guessing about it, change it with a soild state one. Much more consistent and stable. You should be able to get it at your local part store.
djm914-6
Jun 1 2005, 09:25 AM
How would one go about looking for an aftermarket one. I never did trust those counter boys with selecting parts.
Mueller
Jun 1 2005, 02:20 PM
QUOTE (djm914-6 @ Jun 1 2005, 08:25 AM) |
How would one go about looking for an aftermarket one. I never did trust those counter boys with selecting parts. |
well, you could call and ask what brand it is
Pelican shows a Bosch (OEM?) unit for $40, i'd guess an aftermarket unit has got to be much cheaper, that would be a clue on it being aftermarket or not.....
no problems with my Kragens special aftermarket VR
some of the FLAPS should be able to test them for free as well....
wilchek
Jun 1 2005, 02:59 PM
The part is used in a lot of VW. Not that special, not that big of a deal the part I got does not cover the plug like the original but has a wire that has the plug on the end. I was weary at first but it has been rock solid and the volt gage runs at 12 even with the lights on and the heater motor running. My old jetta didn't even do that. BTW, the red light still comes on the dash at idle at night when I run all the assc. and get on the brakes.
djm914-6
Jun 1 2005, 03:08 PM
QUOTE (Mueller @ Jun 1 2005, 03:20 PM) |
Pelican shows a Bosch (OEM?) unit for $40, i'd guess an aftermarket unit has got to be much cheaper, that would be a clue on it being aftermarket or not..... |
Mike, have you been hanging around with the good Capt'n again? Sounds like a Krusty reply to me.
That said, for $40 I'd order one from PP.
Rouser
Jun 1 2005, 03:59 PM
Ask the counterperson for a Borg-Warner Electronic Voltage Regulator, Part # R588.
Works fine ... last long time ...
