stevegm
Jan 22 2018, 06:48 AM
I’m looking for a 914-6 relay board.
sixaddict
Jan 22 2018, 11:02 AM
Me too ...have had people laugh at me
...sorry to be so encouraging.
QUOTE(stevegm @ Jan 22 2018, 04:48 AM)
stevegm
Jan 22 2018, 08:44 PM
QUOTE(sixaddict @ Jan 22 2018, 12:02 PM)
It seems like one came up for sale on here a year or so ago. I’ll just keep looking.
Bernie B
Jan 24 2018, 01:21 AM
QUOTE(stevegm @ Jan 22 2018, 06:44 PM)
So what would one of those be worth?
bdstone914
Jan 24 2018, 07:11 AM
QUOTE(Bernie B @ Jan 24 2018, 01:21 AM)
I got $300 for the only one i have had.
gcrotvik
Jan 24 2018, 07:57 AM
I paid $500 for mine a year and a half ago and was glad to get it.
stevegm
Jan 24 2018, 08:45 AM
When I do find one, is there any way to make sure it works?
toolguy
Jan 24 2018, 09:35 AM
May be a dumb question but can you modify a 4 board to work ??
I tend to agree, it will be one of the hardest SIX OE parts to locate.
raynekat
Jan 24 2018, 03:47 PM
I got mine a year or so ago from Camp 914 and it was about $300-400.
Anyway to make sure it works?
Well, I put together a wiring schematic for the 914-6 relay board and used my multimeter checking every terminal on the board.
Ended up finding two open circuits that required a bit of soldering on the backside and re-potting.
That's the only way I know to absolutely be sure the board is functional.
Any other questions about that, PM me...
914Sixer
Jan 24 2018, 04:15 PM
You can use the stock -4 board with some pin rearranging if I remember correctly. The -6 board is unique only because it has the tach ballast and the engine EGR relay. Most people took out the EGR relay because it caused fuel problems for the carbs. A tach ballast can easily be installed by all the known repair shops. MOST 911 tachs from 1971 on came with ballasts in them. You just have to check.
raynekat
Jan 25 2018, 09:22 PM
Since I've been thru this in the last 6 months...it's fresh in my mind.
The unique things the 914-6 relay board has are the following:
1) socket for the RPM Transducer/Speed Switch
2) Cold start relay
and that's about it.
Since I was installing an MFI engine in my car, I wanted the RPM Transducer/Speed Switch.
Pretty essential if you're doing this kind of engine.
Likely the same if you're going with carbs.
I rewired the rear window defogger relay as my fuel pump relay.
The great thing about the 914-6 board is that it's not all clogged up with the 914-4 fuel injection computer inputs/wiring.
The 911 engines are very much more simple.
The 914-6 board has enough extra traces that you can run most of the extra gauge wiring, etc right on the board.
I ran everything...I mean everything I needed through the 914-6 board and added a couple extra wires to go down through the tunnel to take care of all my needs.
Couldn't have done that with the 914-4 board.
That's just much thoughts.
I have a wiring schematic of the 914-6 board and how I used it with my 2.7 MFI engine if anyone is interested.
I'll send it free of charge to those interested.
IronHillRestorations
Jan 26 2018, 08:37 AM
I had an email exchange with a couple parts collectors about 6 relay boards about a year ago, and they felt like a perfect board with all the components was $8-1000 which seemed on the high side to me, but then again try to find one. I've got one in my "black hole" and was curious as to the value.
As raynekat can probably attest, a lot of MFI parts were cast aside years ago, and getting good working parts can be difficult.
Cracker
Jan 26 2018, 09:12 AM
I have been "just late" on a few items...Glenn (Stazak) isn't only hoarding cars...parts too!
Cracker
Jan 26 2018, 12:32 PM
QUOTE(Cracker @ Jan 26 2018, 10:12 AM)
Cracker
Tony - Did you ever call Len
I remember when Chris Foley was selling a NOS 6 board for $600 and that seemed high.
stevegm
Jan 26 2018, 05:43 PM
Thanks for all of the feedback. I’d like to find an original six board. I’m in no hurry.
raynekat
Feb 2 2018, 12:27 AM
sixnotfour
Feb 2 2018, 02:32 PM
asse bros, back in the day ,,all day long $100 NOS bought a few
Cracker
Feb 2 2018, 02:41 PM
DOUBLE your money...I'll give you $200!
Cracker
QUOTE(sixnotfour @ Feb 2 2018, 03:32 PM)
sixnotfour
Feb 2 2018, 05:47 PM
Only have one , wish I still had a few,,,ah the good ole days
