I've got a problem with my 74 914 2.0. It has dual weber carbs and an aftermarket 009 distributor. When I let out the clutch and start out the car boggs down for a second or 2 then accelerates smoothly. Once it gets past this hesitation it pulls very strong but will hesitate alittle when I change into a higher gear for a second or 2.
My mechanic Billy calls this an off idle bog and said it could be caused by one of the list.
-go up one size on the idle jets -advance the 009 timing alittle
-adjust the accelerator pump on each carb for more squirt
-replace the 009 distributor with a better Bosh 050 or
-go back to a factory Bosch fuel injection distributor with vacuum advance canister
He seems to have covered a lot of options. Any other ideas? Thanx L
