raynekat
Jan 25 2018, 09:51 PM
What are the size bolt M?x? for the door hinges on these cars?
Are the M8x16 cheeseheads?
Guess I'd need 12, 6 per side or 3 per hinge.
There's a flat and lock washer that goes with each?
Thanks in advance....
914werke
Jan 25 2018, 10:25 PM
Actually they are a special pointed or tapered bolt used only on the hinges of the doors
I think they are M8 x 1.25 x 35 or the like.
And yes Washers & split lock washers.
cary
Jan 25 2018, 10:45 PM
Click to view attachment Click to view attachmentTop secret. There should 2 in each hinge when you pull the door braces.
bbrock
Jan 25 2018, 10:48 PM
I happened to have one in front of me when I opened this, so snapped a quick pic. Threaded length is 22mm and 28mm from shoulder to tip of point.
raynekat
Jan 25 2018, 11:50 PM
So is that the bolt that holds the hinge onto the door?
or holds the hinge onto the body?
I'm after the latter one....what bolts the hinges/doors to the body.
cary
Jan 26 2018, 12:05 AM
QUOTE(raynekat @ Jan 25 2018, 09:50 PM)
Hinge to door is a big rivet dealy.
cary
Jan 27 2018, 09:57 AM
Here's what's not in the project door braces. In case you cant find yours.
