Hello everyone,
I've foolishly decided to rescue a 914 powered by a Chevy 350. A new clutch (stage 2 organic) and pressure plate from Kennedy arrived. When installed the fingers of the pressure plate become completely pressed in, leaving the throwout bearing very lonely. So I pulled everything apart and took some measurements as you'll see in the pictures below. The depth of my recently resurfaced flywheel is much smaller than the height of the pressure plate and clutch. Do I need to shim the pressure plate for this initial install of the new clutch? It looks like a significant amount of shimming will be needed. Any advice would be appreciated.
-Bill
