QUOTE(malcolm2 @ Jan 29 2018, 11:07 AM)
QUOTE(moost @ Jan 28 2018, 06:39 PM)
How safe is it to drive with this much rust....?
And would you guys recommend undercoat or por15 for these pans.
Click to view attachmentHave you or someone else already gotten all the sound proof mat off of the floor? If it is still there, get a heat gun and one of those 7 way paint spatulas. Melt and scrap it all off, then you can take the rust down to metal.
Go ahead and get all your carpet, vinyl, seats, back pad, pedal cluster, speaker pods, hand brake, seat rails, etc... out of the car. So you can get in there and of course see it all.
The POR-15 has a 3 part process, Marine Clean, Metal Ready (zinc coating) then paint. It has worked for me on several projects. The metal ready will stop the rust.
Is POR kind of like the original sound deadening material vw used?
QUOTE(Amphicar770 @ Jan 30 2018, 04:51 PM)
Por-15, imho, is crap. It will trap moisture and eventually peel.
Bring it down to bare metal, get rid of any rust, epoxy based primer.
Does the rust oleum undercoating not prevent rust like it should? I'll stick to your guys advice and sand it down to the metal and use por or epoxy primer and sand/paint. Thanks
