gcrotvik
Jan 29 2018, 11:12 AM
There is a set of 911 E Heads on eBay that seem to be in descent condition. The description states there is rust on them (corrosion). What's the consensus on these? Are they rebuild-able? Worth the asking price?
https://www.ebay.com/itm/Porsche-911-1972-1...119.m1438.l2649Greg
bdstone914
Jan 29 2018, 03:12 PM
It used to be that 911 heads were all over E bay at about $100 each with few buyers. Hard to tell if the corrosion is more than cosmetic. Sound like a high price for not so great heads. Is that what you want are E heads ?
flyer86d
Jan 29 2018, 03:47 PM
Well, they need some work. It is hard to tell if the corrosion on the jug to head sealing surface is cosmetic or deep pits which will need to be machined off. If you cut one head, you have to cut them all the same amount. If you cut the sealing surface. I would shim the bottom of the jug an equal amount so that you avoid having to mill the cam boxes. Some of the exhaust studs are broken and need to be replaced. You’ll need new guides but they all need guides.
The date code is 9 and 10 of 71 so I assume they are 2.4 heads. 2.2 and 2.4 liter T and E heads have the same small 32mm ports but they can be opened up easily. They share the same valve sizes so E heads are not worth any more than T heads IMHO. S heads are the same except for port size and I wouldn’t pay a dime more for them.
Charlie
gms
Jan 29 2018, 04:01 PM
Price seems high to me. what about these
73 heads
gcrotvik
Jan 30 2018, 08:19 AM
QUOTE(gms @ Jan 29 2018, 02:01 PM)
73 headsThanks Glenn. T heads will work for my project also.
Greg
sixnotfour
Jan 30 2018, 08:29 PM
at least you get valves and shims retainers etc,, they have very small ports and a big hole to plug from the injectors...still a better deal,,, the chamber and valve size the same...
porschetub
Jan 30 2018, 08:39 PM
QUOTE(gcrotvik @ Jan 31 2018, 03:19 AM)
Greg
Greg did your score the heads that Glen put you on to?,IMO a good buy
Those rusty ones were overpriced as mentioned.
