thelogo
Jan 29 2018, 03:27 PM
Anyone tell me what year and where to look for this wheel
And what issues should i expect when trying to install on the teener
https://inlandempire.craigslist.org/pts/d/p...6453937885.html
PanelBilly
Jan 29 2018, 03:39 PM
I have the same wheel on my car. It’s off center so it gives you more leg room when your steering straight and it gets tighter when you turn. Not a problem for me but I plan to lower the floor pan to give me extra head and leg room soon. Bolt right up with no adapter.
Jan 29 2018, 03:54 PM
Looks big and heavy ...
Dave_Darling
Jan 29 2018, 05:05 PM
We got a used one from an 86 Carrera. Put it in my wife's 911SC. We got it because that particular one had the extended hub, moving the wheel away from the dashboard a bit.
I would expect that you would need a different steering shaft with splines for the 911 wheel, and you'd need to drastically modify the plastic cladding on the steering column in order to fit the wheel at all.
--DD
burton73
Jan 29 2018, 05:06 PM
I had the very same wheel on my 86 Carrera that needed the leather stitched. I never liked the look of that wheel and I bought a brand new one from a Turbo Carrera. No idea how to get it to work on non-911 or 914-6 steering column. Crest extra.
Bob B
Today Porsche 911 930 930S Sport Steering Wheel Genuine NEW
$895.00
brant
Jan 29 2018, 05:13 PM
These wheels come in two different flavors
One is splined for a 944. The other for a 911
I no longer remember when the 914 splines changed
I thought the 914/6 had the same splines as a 911 but notlater 4’s
Like I said I dont remember
However the wheel still won’t be the correct depth to the housing
I run that wheel
Mine was a 944 part number
I bought a 944 steering shaft and had it cut off to the correct length and then had a machinist respline it for me
Jan 29 2018, 05:59 PM
Early 911, 914-6, early 914 all have the same splines and shaft. The later 914-4 ‘72 on, changed the shaft slightly. Still the same splines but sits a bit different due to a chamfer. I don’t remember when 911’s changed splines to the later wheels.
burton73
Jan 29 2018, 06:02 PM
posted twice
