QUOTE(worn @ Jan 31 2018, 09:11 AM)
QUOTE(Dave_Darling @ Jan 30 2018, 09:09 PM)
Those bearings are rather expensive.
--DD
Take your breath away pricey.
Last I checked it was $1300 for a set of the big six bearings; both pinion, both input shaft, and both differential bearings. I get and sell them at a substantial discount sometimes. Usually, I only get enough to keep some on hand to keep up with build demand. About time to make another order.
The Elring seal kits are "complete", but if your wrench is able to check/verify/adjust the pinion then you can order intermediate plate gaskets from Porsche in multiple thicknesses. The ones in the set are all 0.24-.25mm. You can buy specific ones to match your old one if you wish. However, close has been good enough if that is all you are left with. The kits have the seals you will need. Couldn't tell you the cost there, here they are anywhere from $30-40.
For bands, that is a varied price range, too. I can get new for same or slightly less than retail and may be able to save you some on shipping as we all know that parts dealers tend to run up the bill there. Its an option if it works for you.
