Full Version: Gauge restore and LED upgrade
iankarr
Hi Guys,
Just finished restoring my gauge cluster and installing the LED upgrade described by Timothy_nd28. Here's the vid...
https://www.youtube.com/watch?v=r3xJxEiIlIQ
And here's Tim's step by step post...
http://www.914world.com/bbs2/index.php?sho...=212130&hl=
Coondog
Thank you for posting, this mod is on my bucket list for sure.
pete000
Does the dimmer still work?
mtndawg
Easy to follow, clear audio, nice close up shots, really well done video!
iankarr
QUOTE(pete000 @ Jan 31 2018, 12:59 PM) *
Thanks guys.
the dimmer worked on my '73 with this upgrade. haven't installed this new cluster in my 74 yet, but no reason to think it wouldn't work as well.
porschetub
QUOTE(cuddyk @ Feb 1 2018, 07:51 AM) *
Thanks guys.
Done this myself and yes it is very effective,I purchased 3 x 300mm LED strips already to go in,on the tach I found that was a little short but didn't have any effect as there was plenty of light.
My dimmer is bypassed as with my headlight switches both had dimmers fail one after the other headbang.gif .
Great video beerchug.gif .
timothy_nd28
I nominate this procedural video for the classic section! Pictures don't do these upgrades any justice, however your video of the gauges being lit up did the trick.
Since doing these conversions for other members, I did learn something not good since my original writeup, a electrical short. The flexible LED strip has a sticky adhesive on the back end. For whatever reason, when sticking the LED's inside the gauge can, the bottom of the flexible PCB shorted to the metal. Not taking any chances on future conversions, I have been applying a layer of double sided sticky foamy tape to the interior of the gauge can, then appling the LED strip ontop of this tape. The tape acts as a good electrical insulator and it also doubles as something to grab ahold of any loose light bulbs that happen to fall out of its lamp holder biggrin.gif
iankarr
Thanks for the heads up Tim!
Chris914n6
Happen to measure the thickness of the glass?
I've got a guy that will cut glass cheap but my later gauge, with the plastic lens, is about half as thick. Same thing with my 944 combo gauge, only 1/16" or so thick.
bbrock
Nice video! FYI, you can solder leads to any of the copper pads on the cut lines of the LED tape. it doesn't have to be just at the soldered ones. beerchug.gif
ConeDodger
Nice!
iankarr
QUOTE(Chris914n6 @ Jan 31 2018, 09:05 PM) *
Here ya go... this is original glass. 2.92mm / .115 inches (or 7/64). I replaced the ones on my gauges and just told the glazier to match the thickness. keep in mind that if you powder coat the rings you may need a slightly thinner glass. These lenses are installed under surprisingly tight tolerances and if the glass/ring combo is too thick, there won’t be enough metal left to re-crimp.Click to view attachment
Chris914n6
I found Model Masters 28913 Red Orange to be a near perfect match for needles. Should be found at your local hobby store with models.
IPB Image
gothspeed
Kansas 914
QUOTE(Chris914n6 @ Jan 31 2018, 08:02 PM) *
IPB Image
stickyfingers
Hi Ian. Video is amazing. Can someone recommend the LED strips from Amazon that will work?
Thanks.
Retroracer
QUOTE(Chris914n6 @ Jan 31 2018, 07:05 PM) *
I see the OP posted above in the thread (post #12) the measured thicknesses. Its worth noting that if you do replace the plastic lenses with glass, then either use a bezel that came with OG glass lens, OR match the thickness of the plastic with the replacement glass. If you don't, re-crimping the bezel will be a bear of a task.
- Tony
PS. @Iankarr Excellent video there!
JamesJ
Just a comment regarding the LED strips. Palo Alto Speedometer suggested I use LED bulbs because the LED strips emit different lighting for each gauge because each housing is different. YMMV
NARP74
Since we are revisiting the past, where does one source the bulbs for an upgrade? My son was just asking if I was going to do this mod?
Geezer914
I replaced all the bulbs with blue LED's except the generator bulb.
FlacaProductions
QUOTE(NARP74 @ Aug 19 2022, 08:52 PM) *
http://carmagic.us
porschetub
QUOTE(JamesJ @ Aug 19 2022, 01:00 PM) *
Could be but prepared to live with that,I had the led lamps but wasn't 100% impressed but certainly an improvement over stock lamps.
The lamps were a patchy light , the strips are a fully lit housing and no shadowing ,had the same effect with my tacho ,I really liked the end result and little effort as I had both gauges apart anyway.
