Click to view attachment So here's the engine side measurments. The only dimensions thats important are
the mating Surface to flywheel edge (42,5 mm) and flywheel edge to pilot bearing edge (40,9 mm)
Click to view attachment Here's the gearbox side, the important dimensions here are the input shaft nose to the mating Surface distance (10 mm) and the 22 mm distance from the shaft nose to the start of the splines. My guess is that the pilot bearing should rest on the flat
part of the 22 mm dimension.
Click to view attachmentThis is what it looks line when I align the Engine and gearbox mating Surfaces.
The flat part of the input shaft only rests with 2.8 mm inside the bearing which means its barely touching the needle rollers.....
It this enough? Dr Evil, confused patient seeking consultation....
