QUOTE(Biggles @ Feb 3 2018, 10:37 AM)
Hi. My fuel sender has stopped working (there is power to it so it’s a mechanical fault).
Anyone taken one of these apart and if so how/any photos? It’s a 1970 car if that makes a difference?
Thanks
Chris
You will probably need to take it out of the car. Sometimes simply moving the float up and down will do the trick if you rub the contact along the windings. Plug the hole with a rag tightly so no fumes escape and once the gasoline.uhmm petrol, has dried up, you can hook up the wires and see if it works. There are also dismantling threads for this. Mine wasn't working when I bought the car, but by the time the float had moved up and down from the repeated fueling during the long trip home it started working. Common problem with corrosion over the years. Good luck.
