So, I finally had some time to pull apart the front end and find a home for the new control arm bushings, bilsteins, ball joints and turbo tie rods. In the process I got my first good look at the torsion bars on this car.
One end is stamped "18" (which I assume means it's the stock size).
The second pic shows what appears to be a large wear area (the paint is gone) with about a 1mm ridge cut into the side near where the bushing was.
I assume I should replace? If so, then with what? I'd like to stay close to stock and can't seem to find anything lower than 21, which seems like a big jump from 18 for a street car. FYI I plan on putting 100s or 110 springs in the rear. Front sway bar will be installed this week.
Thanks!
