QUOTE(effutuo101 @ Feb 4 2018, 02:12 PM)
I don’t have any of the heater stuff. I used a Tilton 3 reservoir to handle front, rear and clutch.
That Tilton three chamber is what I used and Scott is using on PORSTI and Grey Matter Builds, solves the issue with the other stuff that leaks at the bottom. You can get it with press on fittings or AN fittings. It will fit with the heater stuff in place, you just have to build the mount.
Somewhere in the build thread I have one made up.
Click to view attachmentClick to view attachmentA little
in a vice I need a Magna Brake Make my stuff look so much better
