stags14
Jun 1 2005, 02:28 PM
I have to install new floorpans (crossmember and firewall as well).
1) Do I need to brace the vehicle in any way to prevent warpage?
2) Should I do this with the car up on jackstands or resting on the tires?
Any other tips would be appreciated.
Stags
Verruckt
Jun 1 2005, 03:37 PM
I had the same question (doing the exact same thing as you). Got some good answers in my thread.
http://www.914world.com/bbs2/index.php?act=...f=2&t=31535&hl=
skline
Jun 1 2005, 03:43 PM
These are good valid questions, I cant believe someone has not stepped up to answer them yet. I have never done a floor board yet, but I am getting ready to do a rear trunk floor. I will be doing the very back section as it has rusted through. I wont have to worry about bracing as that is not a structural point for the car. Common sense tells you that because the fllor is structural in these cars, you will need to brace both sides. You can go from the hinge points to the door latch area or I have seen people use braces across the top targa bar to the windshield ring. You also may want to consider using Engmans inner long kit. It is a very good and solid kit for making these things rigid. Do not put it up on stands till you make sure it is straight and solid. If your door gaps are all good and you are happy with the fitment of the panels, then make your braces at that point and then put it up on stands. You asking these questions tells me that you have a pretty good idea of what you want to do and how to do it. Good luck and post pictures for everyone to see what you are doing and how. It will help future owners do their own.
