QUOTE(Mitox @ Feb 12 2018, 04:25 PM)
I have the same wheels for the front of my 914 GT project. I haven't mounted them yet, and was thinking about using the Boxster brakes also. Were your problems with non-S calipers or S calipers?
I assume it was Non-S, but want to be sure.
Thanks
The problem was in the rear. I have a stock bodied car. I thought maybe they could squeeze in there but when I went to mount the wheel it hit the caliper on the inside. I could use a small spacer but then the tire would stick out even further not allowing the tire to fit on the outside. I have non-S Boxster calipers on all four corners. Unfortunately the only wheel that I think will fit with my calipers/stock body is the Boxster 16" wheel that I have on the car now. I guess I will have to do flares some day.
