QUOTE(Cracker @ Feb 12 2018, 08:27 AM)
I believe that would be difficult to achieve without a significant investment in robust driveline components. For instance, Tilton engineers use a +40% clutch/pp formula for reliability and performance. My car would require a pack capable of 800 ft lbs; then there is the transaxle, cv's, axles, etc. Interested in knowing what you do! Remember, talking about something in advance of an achievement is hollow-bragging; afterwards = reporting of facts.
T
QUOTE(Andyrew @ Feb 12 2018, 12:43 AM)
Im looking to go low 11's @ 130+.
Just reporting my goals
The good thing about a turbo is I can dial in the torque, I can keep the torque down where the impact will be higher and dial the HP up with the RPM since I have such a high redline (8250) and the turbo to push it. I already have such a slow onset of boost at 16psi, when I crank it up to 30+ the ramp rate will be much quicker and thus I'll need to control it more. With my nifty boost controller I can do just that.
My CV's should handle the torque just fine, The Trani wont take very many hard launches. The oversized clutch/pressureplate combo and stage 3 components were built for an engine with much more torque onset than mine is capable of creating and should be good for 450lbs+
Again, IM just benchracing as you mentioned. I see the 11's as the difficult part. The 130+ should be doable as I can baby the driveline components there.
Im sure I'll get out there and run a 3sec 60ft
I need to get mine reliably on the road first.
