It appears that these are tricky to get out. Do you remove the cables that attach to the ventilation controls in the dash, or did the dash cables come out with these?
Any been there/done that that tips to pass along?
Thanks for the coaching!
aharder
Feb 15 2018, 09:22 PM
I had to remove the clips and separate the two and then it was still a bitch to get mine out, with fuel tank in.
Feb 15 2018, 10:06 PM
It's much easier to remove the cables from the vents than trying to remove the other end of the cables from the controls ...
rhodyguy
Feb 15 2018, 10:14 PM
Label everything. You need to buy a good penetrant and start spraying all of the connections.
burton73
Feb 15 2018, 10:33 PM
QUOTE(rhodyguy @ Feb 15 2018, 08:14 PM)
Yes you pop the clip and then move the cable till the bent cable ends can feed out. Don’t cut you hand on the clips.
Take it slow and yea mark everything!
Bob B
Mowog4
Feb 17 2018, 09:12 PM
QUOTE(burton73 @ Feb 15 2018, 09:33 PM)
Bob B
I have a pretty stupid question. How does the airflow go through these pieces? Mine were missing when I got the car, now I am trying to understand it.
Tdskip
Feb 17 2018, 09:31 PM
Thanks gentlemen - will give this a go tomorrow.
burton73
Feb 17 2018, 10:13 PM
I think the air comes through the cowl and into the box and the fans push the air through the flappers that you are removing. There are connected by an air tube. I am inclosing a picture of my 6 for you to see easer on a fresh job.
