Full Version: Home soda blasting
mtndawg
This was done with the small soda blaster from HF and a smallish compressor. I had 2 fans that looked the same. I took one apart, wiped it off with simple green and blasted away, then washed it with vinegar. My understanding is, that neutralizes the soda. Pretty cheap and it looks new.
Mueller
Looks good...gets a little dusty huh?
They are balanced so mark them before you take them apart.
mtndawg
QUOTE(mepstein @ Feb 16 2018, 12:55 PM) *
Good callout. I marked them so they would go together in the same position. There are weights around the edge.
