yarin
Jun 2 2005, 08:33 PM
Someone on here said its a 69-70 bus motor.
What is the coil thing?
Is that an oil temp or pres sensor? Is it stock?
Isn't the stock oil pressure switch on the top of the block?
Thanks
Allan
Jun 2 2005, 08:40 PM
Thermostat bellows...
Oil temp sender...
cametal
Jun 2 2005, 08:41 PM
Other piece, oil temp sender.
Jun 2 2005, 08:42 PM
QUOTE (yarin @ Jun 2 2005, 07:33 PM) |
What is the coil thing? Is that an oil temp or pres sensor? Is it stock? Isn't the stock oil pressure switch on the top of the block? |
the top "coil thing" is the thermostat that controls your cooling flaps. it's stock.
that wire hanging from it need to be routed around the plastic wheel and then goes straight up and hooks into the arm for the cooling flaps on top of the engine.
the "thing" on the underside of the engine towards the front is the oil-temp sender.
it's stock on some cars, but not all had it. it is supposed to be hooked up to a green/black wire that comes out of the main harness right under the battery tray ...
yes, the stock oil pressure switch is on top of the engine.
Andy
yarin
Jun 2 2005, 08:44 PM
Hmm... cooling flaps? Do I need them?
The car has no heat (headers). I'm confused.
Allan
Jun 2 2005, 08:49 PM
Yes you need them.
Here is why.
MattR
Jun 2 2005, 08:57 PM
Basically the thermostat is normally compressed. When the engine gets hot it "relaxes" and opens up the flap to the oil cooler. Without it warmup takes forever. These engines like to be cool, but not too cold. It will all make sense if you take a look at the flaps in the fan housing.
The flaps have nothing to do with headers, only the oil cooling.
joeav8tor
Jun 2 2005, 09:41 PM
the cable coming off of the thermostat goes around the plactic wheel and goes up through the engine tin. the cable keeps the flap on that side in the closed position...at the same time the flap over the oil cooler is open...when the thermostat heats up andexpands it opens the flap on the side with the cable and closes the flap over the oil cooler...directing more air through the cooler.
Joe
9144guy
Jun 2 2005, 09:49 PM
im not sure if im going to run them, we have 3 cars at work that dont run them. 2 are daily drivers /race car. it dosent get below 30's here. building my motor this weekend.
Bleyseng
Jun 2 2005, 10:19 PM
Its not about how freakin cold it is, its about heating up the engine as fast as possible to operating temp. That is also why water cooled engines have a thermostat too. Slow warmups mean premature wear as a cold engine wears the most.
9144guy
Jun 2 2005, 10:28 PM
duh? it will be fine, that engine warms very quick
Jun 2 2005, 10:36 PM
QUOTE (yarin @ Jun 2 2005, 07:44 PM) |
Hmm... cooling flaps? Do I need them? The car has no heat (headers). I'm confused. |
helps getting the engine to operating temps faster. has *nothing* to do with heat for the pass. comp/exhaust/headers ...
either hook it all up right or unhook the wire to have the engine on full cooling all the time. whatever you do, *don't* take off the plastic wheel (the bolt goes through into the case = major oil leak) and *don't* remove the flaps from the fan housing (NO air to the oil cooler) ...
the flaps provide both, cooling air for the oil cooler and cooling air that goes over the cylinders and heads ...
Andy
MarkV
Jun 2 2005, 10:44 PM
I live in AZ where it was 95 degrees today. Before I reinstalled the thermostat it would take a hour before the car was warmed up. Now it will warm up in 10 minutes.
Zee Germans designed all air cooled engines with a thermostat for a reason.
yarin
Jun 3 2005, 06:18 AM
Ok.. I got it now. That pic is from my old motor, sitting on the garage floor right now.
My "race" engine doesn't have any such device. I will keep this info in mind when rebuilding my motor.
Thanks!
joeav8tor
Jun 3 2005, 06:48 AM
the germans are excellent engineers, they built the system with a thermostat for a reason...will it run without it? people have said they dont use the system for various reasons....it seems like a good idea to me for the above reasons stated.
Joe
solex
Jun 3 2005, 06:54 AM
unless your ambient temperature is 212F then leave the thermostat in and connect it to the cooling flaps, your engine will last much longer with it...
yarin
Jun 3 2005, 11:03 AM
I agree with the saying... the engineers put it there for a reason.
The motor in the car does't have this installed, but the other motor does. How do I tell if these flaps are under the cooling tin?
I noticed a port on the impeller housing is capped.
PicWhat is that about? Part of the old heating system? Or flapper system?
Jun 3 2005, 11:14 AM
QUOTE (yarin @ Jun 3 2005, 10:03 AM) |
Part of the old heating system? |
yupp, no problem with that blocked on an engine with headers ...
if someone had removed the actual cooling flaps, you would know after about 15 minutes of running your engine as it would get red hot and explode on you ...
no flaps = *no* cooling air to the oil-cooler !!!
Andy
Cap'n Krusty
Jun 24 2005, 12:17 PM
NOT a 69-70 bus motor. Bus didn't get a T4 until 1972, never had a temp sender, and didn't come with a '73+ 914 motor mount. The Cap'n
