daytona
Feb 20 2018, 09:45 AM
Hi all,
I am looking for help again. I am trying to remove a glove box from a parts car so I can install it on the 6-conversion build. Does the dashboard have to come out in order to remove the glove box? These things are fragile and I don't want to ruin it so I figured I better ask those who know.
Thanks,
Bill.
Feb 20 2018, 09:53 AM
Held in by a metal strap behind the box. You can reach under the dash and remove one side of the strap. a small flashlight will help you see the connections.
Morrie
Feb 20 2018, 10:04 AM
Just use caution to not remove the glove box door hardware if you don't need to. It is a pretty involved project to just get the dang springs attached.
daytona
Feb 20 2018, 11:04 AM
Hi guys,
Thanks for the responses.
I will not touch the glove box door. The project car has the glove box door in place it is just missing the glove box compartment.
I am so happy right now that I don't have to remove the dashboard in order to remove and install the glove box compartment.
Thanks again. Will let you know how it turns out.
Bill.
simonjb
Feb 20 2018, 11:41 AM
Just put mine back in. Its easiest if you remove the radio. Then you can get access to the nut that holds the metal strap on.
daytona
Feb 20 2018, 04:09 PM
Thanks for the tip simonjb.
daytona
Mar 2 2018, 03:10 PM
Hi guys,
I have follow the directions offered here but I still can't get the glove box compartment out of the donor car.
I have removed the strap that holds it in place, and the compartment is now loose. I have moved it in very direction and wiggled it, but it still will not come out. There doesn't seem to be anything in its way. The box seems a bit brittle and I am afraid of braking it if I force it. Any hints???
Thanks,
Bill.
simonjb
Mar 2 2018, 04:45 PM
As long as two inside screws are removed and the strap - it should come out - Down and towards front of car. I did use a reasonable amount of force.
simonjb
Mar 3 2018, 12:11 PM
Silly question, but you did take these two screws out right?
Morrie
Mar 3 2018, 12:15 PM
Hi Guys,
When I replaced mine, I combined notes from threads and condensed into enough information to get me through the process. See if these cheat sheet summaries help you out. Nothing new, just notes and pics you could print and take to the car, if that helps.
Click to view attachmentClick to view attachment
