Picked these up from a respected World Member and swapped out one reflector that was in better condition than mine. However, I added a cleaner set of TN4 lenses as one was broken. One of the rings is dinged and some corrosion is present in one of the housings although not noticeable once reassembled.
The only thing you will need is a replacement set of seals for the lenses and 914 Rubber has got those available with the protective lens protectors.
Clean them up and run as is for a good driver quality set or powder coat & pick up a spankin' new set of lenses from 914 Rubber and restore to new.
Price is $85.00 plus applicable shipping or local pick up in SoCal.
Click to view attachmentClick to view attachment
