sixaddict
Feb 25 2018, 06:35 PM
I am trying to remove baked on brake dust from ( inside) of a set of 911 Fuchs wheels.....Without screwing up the polished side...
Any experience .....Trying to get surface to attach wheel weights ( shop wouldn't even address ( understandably).
Thanks
n2j2ryan
Feb 25 2018, 06:45 PM
I bought a little steam cleaner. Used it on my underbody, suspension and brake parts. Worked brilliantly. Had to be patient under the body as it wasn't too big but just took my time. Awesome for smaller parts.
914Sixer
Feb 25 2018, 07:45 PM
Go to the Dollar Store and get a quart bottle of Amaze cleaner. Give it a try.
Feb 25 2018, 07:58 PM
I use brake kleen. Spray, soak, wipe, repeat. Wear gloves. Lots of fresh air.
sixaddict
Feb 25 2018, 08:25 PM
what I heard Mark say is ..Wont be easy ! Already there..
sixaddict
thanks all
Feb 25 2018, 08:34 PM
Yes, BTDT. A green scrubby pad helps. The longer you can hold the brake clean against the dust the better it works.
r_towle
Feb 25 2018, 08:36 PM
Get the stuff with chlorine if you can, it’s stronger.
Specracer
Feb 26 2018, 06:28 PM
+1 on Brake Cleaner
