buck toenges
Feb 26 2018, 01:23 PM
I am looking for the 2 washers that fit under the reservoir plastic tubes in the 17mm mc. I would also like to get the tube from the reservoir overflow.
thanks,
Buck
914Sixer
Feb 26 2018, 02:03 PM
Overflow tube is just plastic tube. Try the big box stores. Other option is to use fuel line for air cooled motors ( weedeaters,etc)
malcolm2
Feb 26 2018, 02:12 PM
I believe 914 rubber has the washers and the rubber grommets. Inserting those is one hell uva job. Don't stop pushing 'til you HEAR THE CLICK.
I would recommend that you look for a late model fluid res. My 75 does not have the overflow hose.... or the hole in the res.
You might also epoxy up the hole that the overflow hose goes in.... Dripping brake fluid under your car can't be a good idea.
Brake fluid absorbs water. with the system being open from the overflow hose, the fluid is getting wet.... only slightly, but enough to eventually ruin calipers, etc....
Might take a long time, but it can happen.
malcolm2
Feb 26 2018, 02:23 PM
#18 & #19 $6-ishAuto Atlanta is a bit closer to you. Either way they are cheap.
