QUOTE(sholman5 @ Feb 27 2018, 04:25 PM)
They (manufacturer) probaby expect that buyer is going to use an outer faceplate. Instead of period correct unit that has no faceplate.
The radios sold back in the day at the dealers specifically for the 914s were mostly sold with a custom black plastic faceplate specific to the radio, & molded to the basketweave or brickweave texture, & which was specific to each radio, & with the 1/4 round cut-out for the glove box lock.
The ones which were made for both 911 & 914 like Mark's tended to use the leatherette material over a cut sheet metal faceplate covered with cut-out vinyl leatherette basketweave (70-74 MY) or brickweave (75-76 MY) cover. These were often just made up at the dealer or their fab shop locally.
Mark - you're probably better off to clean up the original fitting faceplate in an EvapoRust soak, rust treat with Wurth Zinc Rich Primer, then epoxy or good primer/sealer, & spray it black, then cut your on nice vinyl to fit it properly.
Tom
