there were three rotors, early through 4722919032 short for the single bleeder calipers and early ball joint no centering disc
intermediate from 4722919032 tall hat dual bleeder calipers late ball joint no centering disc
late after 4732901000 tall hat late ball joint dual bleeders wheel centering disc.
Factory superseded all to just two
411407075 for up to 4722919032 short hat no centering disc will only fit the early cars
411407075b for any car after the 19032 production number, tall hat centering disc
Struts were changed in late 72 and the short hat caliper will not fit the later cars. Hence when we tap the rotors on the late cars for the 911 fuchs wheels that will not fit over the wheel centering disc on the rotor, we shave it off
QUOTE(Dougster @ Mar 2 2018, 03:21 PM)
From researching the subject, I understand that the main difference (if not the only difference) between the early front rotors (70-72) and the later model rotors is that the later models have a hubcentric centering ring incorporated into the casting, to center the wheels. I'm looking at getting a set of never used Early front rotors
that have been re-drilled with the 5x130 pattern. They are supposed to be a cheaper method of getting the 5 hole pattern than going the 911 suspension route... just add the right bearings apparently (but I don't know the specifics of that). But my car's a '74 model though. Will they work? Also, isn't that the hubcentric ring in the middle of the rotors, in the following pic of said rotor set?
Doug C
