Can someone advise where to fit the trim on the decklid grills?
I have replacement from 914 rubber but dont know where it fits. Or whether it fits the grills before fitting to the decklid or after.
dr914@autoatlanta.com
Mar 3 2018, 09:16 AM
welting in-between grilles and engine lid (painted part) edging on the edge of the engine lid back bottom and two sides
Mikey914
Mar 3 2018, 10:45 AM
The welting has the J hook to go under the edge of the metal. The sides are a little more tricky as you will have to trim a little. On the side that is not secured down directly I use a dab of contact cement to secure. I also cut the notch from the bottom of the welting to relive the pin areas.
Hope this helps,
And thanks for your business,
Mark
Mikey914
Mar 3 2018, 10:48 AM
Also the protector will slide onto the bottom lip once the grill is assembled. While the factory didn't do the sides I included the material to do them as it looked like it was missing
Superb advice thanks both.
Now i ineed to stop the trunk crushing up against the side piece grill edge.
Mikey914
Mar 3 2018, 11:24 AM
Is this what you need?
https://shop.914rubber.com/Rubber-bumper-to...m?categoryId=-1Sorry the metal is not included just the bumper
Looks like i also need 12 13 & 14. I was making a list to order this week.
Not sure where that stop bracket is meant to fit but it looks like i'll need to add those aswell
Don't know why it's showing sideways
Mikey914
Mar 3 2018, 12:11 PM
As the website is not as easy to search
13
https://shop.914rubber.com/Rubber-hood-bump...m?categoryId=-114
https://shop.914rubber.com/Engine-Deck-Lid-...m?categoryId=-112 I need to identify. we have the speednuts and washers, think it's a washer we have
QUOTE(Mikey914 @ Mar 3 2018, 05:24 PM)
I assume there are 2 of these fitted. Can someone put up a picture of where they're in the trunk hinge area?
Mikey914
Mar 4 2018, 03:53 AM
QUOTE(JFG @ Mar 4 2018, 01:06 AM)
Picture from the website not the best, but I think you get the idea, they go in the "C" shape on the hinge bracket.
That's the engine decklid hinges. I am referring to the bracket to stop the trunk hinges hitting the small grill sections above the battery and nearly above the relay board.
