QUOTE(Mikey914 @ Apr 24 2018, 11:21 PM)
Email sent. The trick is to install the upper corners 1st. The vertical sides do not slide through the track. The back side engages in the inside of the track. You push it forward onto the tab on the aluminum, and install the screw in the corner hole that holds it. Work your way down the sides starting the back 1st. It is a tight fit as it needs to stay in. Use a flat screwdriver to push the front side in. You will notice that the factory took a tool and punched the chrome down at the bottom. You will need to use the same large flat screwdriver to carefully bend the punched part out of the track. Note this is new rubber and will be slightly larger than the old as it shrinks over time. It may be necessary to make some fine adjustments to the tilt of the bar as it's slightly larger. I didn't have to on mine, but I adjusted mine when I fitted the 1st Gen 5 years ago.
Hope this helps we are working on more extensive install instructions.
Thanks,
mark
(Rich/914werke did 99.9% of the work while I tried not to lose too many of his tools.)
Installing the thick lower windshield seal wasn't too bad ... about the effort I was expecting. My car (brought up from California) was missing this piece entirely!
The vertical sides (attached to the upper seal) were quite difficult. Even with glycerin we weren't able to slide it onto the track past the first couple inches due to the small screw heads in the track. We hadn't seen these instructions yet. I gave up, and Rich got them on with a screwdriver somehow.
Click to view attachmentCutting the lower part to mate with the closing door properly was complicated by the fact my car seems to be missing some rubber here. I think it's part of a complex piece that seals the little triangular window. Mark do you sell this piece for a 1970, early-door model?
Click to view attachmentRich also installed the rear targa seal. This probably should have been easy, but some of the screws holding the metal strips didn't want to come out, and also some previous owner had covered everything in duct tape that was beginning to fossilize. Question about that, is the fuzzy part supposed to extrude outside the car as far as this?
Click to view attachmentI'm grateful that 914Rubber sells these parts, and that Rich is willing to install them. On my own I would have given up after the first few snags. Even with just the first three parts installed, the roof fits snugly, rattle and squeak reduced, and not feeling as much of the breeze as I was before. I felt confident enough to take it to a self car wash, first time I've washed it since acquiring last winter.
