BCinSC
Jul 10 2003, 03:24 PM
The old girl's been running kind of rough. How would I know if the valves were getting burned? I was very careful when I adjusted valves, but it was my first time. About to check them again, having driven over 3K miles since.
TheCabinetmaker
Jul 10 2003, 03:57 PM
Bruce, After 3000 mi, it's not uncommon for the valves to tighten a bit. I adjust mine at 2000 mi., or before and after a long trip. Valves are the key to motor longevity. Loss of power and rough idle is a sign of improper valve clearance, but do a complete check of the ignition system at the same time. Valves, plugs, dwell, timing, and fuel system should be set also! everything must be in sync.
djm914-6
Jul 10 2003, 06:45 PM
Three letters: S.... B.... C....
