I would check the relay and make sure that the red with black wire going to the wiper motor and fuse number eight and the wiper switch has power with the key on. If so then the switch or the motor, if not the fuse or the black round relay
QUOTE(914Toy @ Mar 10 2018, 08:26 AM)
My 1972 914 wipers column switch does not turn the wipers on. I have visually checked the multi-plug connection at the steering wheel, fuse panel connections and trunk area for any loose wires - all looks OK. I recently removed (pulled off) the rubber washer lines as I now have an electric pump installed, and the wipers have stopped working since then. The switch has not been used a lot but is probably original. Is it likely that the switch has failed?
