Full Version: Low idle and stalling
sobolewski
Help!
After running the car on the freeway on a warm day the RPMs will be very low once I exit and come to a stop. About 5 minutes after that the engine will finally stall. It will restart if I put the pedal to the floor and crank away. It continues wanting to stall unless I continuously give it gas. Once it cools down it runs fine.
I have had a tune up but it hasn't changed the outcome.
Any suggestions?
1972, 1.7 FI
Thanks!
Bleyseng
#1 the CHT is starting to go and its going rich
#2 the MPS is cracked and its starting to go rich-check it with a vacuum pump
#3 the idle is set when cold but should be set when the engine is hot
Joe Bob
Add intake leak.....
