QUOTE(bdstone914 @ Mar 22 2018, 03:19 AM)
QUOTE(stugray @ Mar 21 2018, 06:29 PM)
I ordered the front monoballs from Elephant racing and they dont fit quite right.
I cant tighten the nut down far enough to get the cir-clip on.
SO I tried another camber plate I had in my parts stash and they FIT!
Called Elephant and they said that the 911 camber plates are just a couple millimeters shorter so the monoballs fit.
Does anyone have a stock 911 camber plate?
You cannot visually tell the difference without measuring.
If you are not sure, I can get the measurement, but would probably need to provide a picture.
There are short and tall camber plates used. Not just a 911 plates. Post s picture of what you have. I do not see why either will not work with monoballs
The "short" camber plate is what I need. They are only different by about 2 mm, but that is enough to keep the upper nut of the monoball from threading down far enough to put in the external C-clip that goes above the nut.
So I need one of the "shorter of the two" types, or just run without the clip.
I can get pictures of the measurement this evening.
