Ok so I need to get this engine back to full short block before my new heads from Len arrive. I bought a new RMS from bus depot. I need to check the RMS first to see it needs to be replaced. I've never tackled this before so I just want to make sure I do things right.
Remove the 6 bolts
Remove cover plate
Remove clutch disk
Remove FW bolts
Remove FW
Check seal for leaks
Reverse order install
Do I need to mark FW so it goes back on exactly the same way?
What is the part number/link to tool for re-installing clutch?
Any gotchas to pay attention to?
Was this all covered in Raby's Type4 video?
Thanks all
