Pelican Quote:
QUOTE |
stock mounts offer a good, although expensive solution that will keep your car original. The sport mounts are 911-style motor mounts that are a direct and less expensive substitute for the original mounts (Pelican Recommended). Finally, the solid transmission mounts are super stiff and will not wear out over time. |
So what do you guys think?
Stock, 911 mounts, or the solid mounts? What if anything is the difference in your experience?
Thanks
-Matt
