QUOTE(Gatornapper @ Sep 8 2019, 01:24 PM)
Yes. Nothing happened. Did not energize the armature, no charging, light went on and stayed on - just like GEN light......
OK, so a higher power GEN light doesn't get the VR started...
Correct.QUOTE
As wattage of bulb was more than 2 watts, the filament being a lower resistance, the voltage hitting the armature would have been higher than that of the 2 watt Gen bulb - and the armature should have been excited and produced a charge.
You applied the 1156 from 12V battery to D+, not to DF.
YES. DF energized is the responsibility of the VR. If the VR is not working, applying 12V to D+ will not energize DF.
HOWEVER, remember - when I hit DF with a full 12 volts - the system charges to a full 14.1 volts as it should........but as soon as you remove the external 12v to DF, the charging ceases. Once energized, the armature should stay excited, producing a charge.
Did you do this with the VR in place?
YES. Once you remove 12V from DF, if the VR is not operating, the voltage at DF could go to zero and the alternator will not function.
3 VR's, 2 which are new, this occurred.QUOTE
So I'm thinking the problem is in the armature.....perhaps a break in insulation that allows leakage of the voltage. I.e., a short.
GN
Your previous test seems in conflict with a bad armature as you were able to get 17V at the battery with the armature initially being driven with the GEN light:
I agree - just stabbing in the dark for what's going on.....QUOTE(Gatornapper @ Aug 31 2019, 09:07 PM)
DID THE D+ TO DF Jumper TEST: at rpm, voltage at battery jumps to 16.9 to over 17.
It still seems like the VR is not starting up. I would be curious to know the voltages at the VR when running. The VR I have on my 914 has a plug and wires connecting to the VR thus I can measure voltages right on the VR plug. They should be the same as the voltages on the alternator plug.
I read zero resistance between each point of D+, DF, and D- between the VR pins and the alternator harness pins.Read voltage from each point to ground? Will do.Here's another test: With VR in place, start engine then short DF to D+ with the 1156 bulb. What you'd be doing is simulating the VR pulling up on DF as it should but seems it isn't. If the battery voltage goes up, then the alternator should be good.
