dkos
Jun 6 2005, 08:17 AM
I'm starting rust repair on my longs, but am having trouble getting the door gaps right. Does anyone have a higher resolution diagram of the measurements? I can't tell from the diagram on the 914 Info page where to take measurements.
I have my car on jacks similar to this pic from a riverman post:
dkos
dkos
Jun 6 2005, 08:18 AM
When I jack the back of the car up to the point where the door gap looks good the, it's too tight where the top of the doorframe hits the windshield frame.
Jun 6 2005, 10:24 AM
windshield hoop could be bend.
happens a lot actually. people used it to lift themselves out of the car, bending it downwards ...
i don't have anything besides the stuff in the "914 Info" section ...
Andy
John
Jun 6 2005, 12:41 PM
I'm with SirAndy. I would consider that the windshield frame is not right.
Just my $0.02, but I would work to get the door gap consistant with the measurements in the 914 info section and make sure your doors look right. I would also suggest to make sure the bottom of the fenders and bottom of the door is perfectly straight. (it looks like it is on your car when your door gap looks right).
You could look at the thread I started to fix my incorrect door gap. There are jigs you can get that basically "fixture" your car to the correct dimensions.
After the door gaps are good and the tub is solid, I would do whatever it takes to get the windshield frame within reasonable dimensions. The windshield frame moves quite easily.
dkos
Jun 6 2005, 08:01 PM
I just realized that there are detail photos linked to the Fig.#s on the Body Dimensions Pagejavascript:emoticon(':blink:') . I feel like a dope...well, kindly disregard my request for a more detailed diagram
and thank you for the tip about the windshield frame bending...I'll stick a couple o' 2x4s in there (like Riverman did in the photo above)
dkos
