DougC
Jun 6 2005, 02:00 PM
I'll be installing the vents for an A/C system and I noticed over the weekend that the cable from the odometer terminates at the bottom of the dash frame (knee pad has been removed). It ends there and a small stub type thing (bolt?) protrudes below the dash frame. My question is this.. should this be relocated somewhere or should I try to fihure out where it will meet the Vent unit and drill a hole to accomodate it? The bottom surface of the dash frame is not smooth because of this.
Doug C
914GT
Jun 6 2005, 02:39 PM
If you want to reset your trip odometer you just need to put it where you can reach it.
Does it work? Mine won't really zero the trip meter, since the last set of numbers is always at least 1/2 off at best. It just seems to roll over every other time when I spin the rest through - 55(half a five), 66(half a five), 77(half a six), 88(half a six), 99(half a seven), etc. So basically, i never mess with it. You certainly don't have to leave it.
DougC
Jun 6 2005, 02:55 PM
Oh, that's the reset button? I had no idea, I'm such an idiot.. thanks.
Doug C
tracks914
Jun 6 2005, 05:47 PM
It should have a 1 cm x 1 cm knurled knob on the end of it in order to rotate it.
