QUOTE(914Sixer @ Apr 3 2018, 07:45 PM)
All the usual places: 914Rubber, AA, SMC,
..... & pretty much any Porsche parts vendor has it, as well as Auto International in Escondido CA, World Upholstery in Ventura CA, & other Porsche 914/911/912 upholstery kit & fabric sellers have the fabric that you can buy a yard or 1/2.
And if you have a sample piece from your own 914, you may be able to take it to a local auto upholstery shop that does imports, to see if they have a match. Sometimes they may even have some extra trim scraps which you canget cheaper/free & cut to fit your dash.
Make sure to use a good quality 3M upholstery adhesive, & do it per their instructions - usually spraying both surfaces, so you'll have to mask the entire interior if in place, per temps & humidity specs, etc. - in order to not have it peal/curl/etc.
Even then, you may get some peeling/curling since they've had to reformulate adhesives for EPA etc., so some don't stick as well as the bulletproof stuff from the 70's.
Good Luck!
Tom
