Tdskip
Apr 4 2018, 06:44 AM
Going to be a street car, civility is important, so what do you all think?
Thanks!
Apr 4 2018, 06:58 AM
I think if you go light, you want to get a custom chip to keep from stalling at 1st gear starts. It maybe fine just to raise the idle speed.
Tdskip
Apr 4 2018, 07:00 AM
Good morning - maybe just leave well enough alone then?
914dave
Apr 4 2018, 08:21 AM
Did some research on this when I built my car. Too light and you have deceleration issues like Mark mentioned. I decided to do without for drivability. It accelerates fast enough for me with my old man reflexes.
Tdskip
Apr 4 2018, 08:32 AM
QUOTE(914dave @ Apr 4 2018, 09:21 AM)
Thank you for the response. I need to track down a 225 mm flywheel anyway, which I presume will be slightly lighter than the 240 mm, so decision made that I'm am going to leave the stock weight.
Thank you very much Gentlemen
Apr 4 2018, 09:01 AM
QUOTE(Tdskip @ Apr 4 2018, 10:32 AM)
A 3.2 is really a strong engine in a 914 no matter how you do it. Curb weight of a mid 80's Carrera was around 2800+ lbs so dropping it in one of our cars makes it feel like its an even bigger engine than it is.
stownsen914
Apr 4 2018, 11:54 AM
If you want more bang for your buck in saving rotating weight, get an aluminum 225mm pressure plate instead of the heavy steel or iron or whatever the regular ones were made of. That will save a lot more weight than shaving a little off a 225mm flywheel. The 225mm flywheels are relatively light to begin with.
Scott
burton73
Apr 4 2018, 12:44 PM
I had this Engine in my 86 Carrera Cab. Put the Steve Wong chip in it and it will pull like you want from a very low RPM all the way through the RPM fight up to red line.
Stock set up is great. 230-240HP
You are going to like it. Now the question on gears it yet to be answered.
Bob B
Tdskip
Apr 4 2018, 03:00 PM
Thanks gentlemen.
I was planning on using the OEM gearbox from the '74.
Justinp71
Apr 4 2018, 03:39 PM
QUOTE(Tdskip @ Apr 4 2018, 02:00 PM)
Thanks gentlemen.
From a 74 911 or 914? I am using a 901 gearbox still in my 3.2, it works well and I like the shorter gears for the track (vs stock 3.2 911). I run shorter tires and I could benefit from longer gear ratios but currently I don't max out my rpm's at any racetrack. I do run at 3,800rpm on the fwy though. 1st gear is pointless .
Apr 4 2018, 03:45 PM
QUOTE(burton73 @ Apr 4 2018, 02:44 PM)
Bob B
If you are using a 914 box, I would get it up and running with the stock gears, especially if the box is in good shape. Drive it for a while and then find a 2nd box to modify if you feel you need something different. It never hurts to have an extra box and you won't really know what you want/need until you drive it for a while.
Tdskip
Apr 5 2018, 08:42 AM
Good morning, and that’s for the responses.
I am going to use the factory 914 gearbox to start.
Why would I want to potentially modify that? Taller 5th? Can’t imagine I would need a lower 1st with a 3.2....
EDIT - looks like I may want a taller 5th gear to lower highway RPM.
Thanks!
pcar916
Apr 10 2018, 06:35 PM
I don't know about the 3.2 but I'm using the Patrick Motorsports aluminum conversion flywheel to an old style 225mm pull-type clutch with my 993 engine. The original Flywheel/clutch/PP on the '95 993 weighs 55lbs and mine is 19lbs.
Before I built the car I was assured that this setup would never allow a smooth idle but that turned out not to be the case. So the 993 DME doesn't mind it. What I don't know is whether the 3.2 DME unit would be as forgiving... never done that conversion.
This clutch is a "sport" version so it's clamping strength is better than the stock version but I haven't had any problems with street drivability, although it's a bit stiffer than some folks like. As for the trans...
Gearing is a shorter 3rd, forth, and a taller 5th with the standard 7:31 diff. Those gears have been fine for years, but you won't be in any one of them for very long if you're pouring the coals to it.
Good luck!
