i love porsche
Jun 6 2005, 02:52 PM
so..this week im taking off all the paint hopefully...whats the best way to do it....sanding? chemical? torch?
i dont want to damage the filler too much because it looks somewhat good...and im not at all good with doing filler or sheetmetal work, ill learn a little, but i dont want to tackle the whole car
so..any suggestions?
914GT
Jun 6 2005, 02:58 PM
The best way to strip paint without damaging the filler is to use a DA sander. Heat and chemicals will soften old fillers.
redshift
Jun 6 2005, 02:59 PM
Chemicals are best, but they play havoc with your filler.. chemicals are the way I strip anything...
... including a woman(*1).
M
(*1.)Goat
MattR
Jun 6 2005, 03:13 PM
I used methylene chloride aka aircraft stripper. It works really well. I stripped the entire car to bare metal in 2 weekends.
A tip for aircraft stripper: cover it with a plastic drop cloth after applying to trap the oxygen and let the stripper work longer without evaporating.
mharrison
Jun 6 2005, 03:25 PM
As they've said. Chemical stripper WILL mess up the filler. If you use these plan on taking it ALL to bare metal and redoing the bodywork.
This would be a prime opportunity to learn to do bodywork. (Minor work isn't very hard at all and you will get a feeling of accomplishment from it!) What color are you painting the car? A light color will had imperfect bodywork well whereas dark will show every flaw.
MattR
Jun 6 2005, 03:40 PM
Exactly. I should have specified: i took my car down to bare metal. Thats how the body shop wanted it. They didnt want to risk their stuff not sticking to old filler.
Joe Ricard
Jun 6 2005, 05:20 PM
I have been stripping the body panels of my stripper with a chisel. Get it under the paint and push. 1"wide blade goes pretty quick. did a whole hood in 20 minutes.
Hey you asked what we do and that's how I do it. Prolly use aircraft stripper in the corners. and funky stuff.
