bd1308
Jun 6 2005, 08:10 PM
i have two questions:
1) How do I remove the CV joint......The bolts are gone but its still attached....whats the procedure here?
2)The engine is caught on the shift rod......it's removed from the back of the tranny but I don't know how to get the rod out of the way........
3) My clutch cable pulley is wearing down......anybody have a GOOD one?
Allan
Jun 6 2005, 08:12 PM
I seperated my CV's with a flat screwdriver. You have to twist the shift rod around and it will slide out. Don't have a clutch pulley.
Jun 6 2005, 08:13 PM
QUOTE (bd1308 @ Jun 6 2005, 07:10 PM) |
i have two questions |
i count 3!
1) BFH tap on it while you rotate the CV and it'll come lose ...
2) you need to disconnect it in the front, near the firewall. there's a allenhead set-screw in the coupler that holds the shiftrod. unscrew & slide out ...
Andy
URY914
1. There is a pin that mates up with holes in the flange on the tranny. Take a flat blade screwdriver and carefully pry the C/V off the flange.
Joe Bob
Jun 6 2005, 08:14 PM
Turn and whack, turn and whack....think of Miles rotating on a spit over a barbeque.....
Aaron Cox
Jun 6 2005, 08:15 PM
CV's - flat screwdriver - use new gaskets on reassembly.
shift rod. 1 CONE screws at the front where it goes into the body. allen head,
get to it!
Elliot_Cannon
Jun 6 2005, 08:16 PM
1. I have used a putty knife to wedge between the cvjoint to seperate it from the tranny. You'll need new gaskets.
2. I remove the engine and tranny both at the same time as one unit. The shift rod should come off before you try to get the engine/tranny out. (you should get a Haynes manual or doundload the engine removal procedure from PP.
3. Sorry, I don't have a spare cable but they are available from all the usual sources. (Don't go to a FLAPS for it).
Cheers, Elliot
Elliot_Cannon
Jun 6 2005, 08:19 PM
QUOTE ("*" @ Jun 6 2005, 07:14 PM) |
Turn and whack, turn and whack....think of Miles rotating on a spit over a barbeque..... |
I like "*" 's procedure even better.
Hey "*" the No Bad Days graffic looks great on my rear window. Thanks.
Cheers, Elliot
SLITS
Jun 6 2005, 08:32 PM
Cone screws are 4mm hex......Harbor Freight tools, set is cheap.
joeav8tor
Jun 6 2005, 08:37 PM
I used a big rubber mallet on the cv joints, tap and turn, a 4mm allen key will remove the cone head screw on the shifter rod near the firewall. When you get new cv joint gaskets store them away from your other parts, they are brittle and will crumble (know from experience, unfortunately)
Joe
street legal go-kart
Jun 6 2005, 08:39 PM
Way to go Kid!
The pully is available from any Wire and Rope dist.
Standard size.If you can't find a wire rope place , sailboat parts will work. Also steering pullys from an outboard moter steering system will work.
Do I detect a marine theme here?
Keep pounding em.
JT
Joe Bob
Jun 6 2005, 09:13 PM
QUOTE (Elliot Cannon @ Jun 6 2005, 06:19 PM) |
QUOTE ("*" @ Jun 6 2005, 07:14 PM) | Turn and whack, turn and whack....think of Miles rotating on a spit over a barbeque..... |
Hey "*" the No Bad Days graffic looks great on my rear window. Thanks. Cheers, Elliot |
Post a pic....
Elliot_Cannon
Jun 6 2005, 09:35 PM
QUOTE ("*" @ Jun 6 2005, 08:13 PM) |
QUOTE (Elliot Cannon @ Jun 6 2005, 06:19 PM) | QUOTE ("*" @ Jun 6 2005, 07:14 PM) | Turn and whack, turn and whack....think of Miles rotating on a spit over a barbeque..... |
Post a pic.... |
That would take computer skills I haven't learned yet.
Cheers, Elliot
Joe Bob
Jun 6 2005, 09:36 PM
Great....he can fly a 747 but he can't post a pic....be afraid....
bd1308
Jun 6 2005, 09:42 PM
shopping list (need ASAP):
*CV gasket
*13,17,18mm wrenches
Joe Bob
Jun 6 2005, 09:44 PM
QUOTE (bd1308 @ Jun 6 2005, 07:42 PM) |
*CV gasket *13,17,18mm wrenches |
whatya need an 18mm for????
19mm is the one you REALLY need as well as a 15mm
bd1308
Jun 6 2005, 10:23 PM
18 is for one of the engine mount....or was it the tranny mount....one of them needed 18...i think its the crossmember bolt.
Jun 6 2005, 10:28 PM
QUOTE (bd1308 @ Jun 6 2005, 08:42 PM) |
* 2 (two) open end 11mm wrenches for the clutch cable nuts ...
Andy
Trekkor
Jun 6 2005, 10:35 PM
ratcheting wrenches are great...
You have the ten point allen CV bolt socket, right?
8mm, I think.
KT
joeav8tor
Jun 7 2005, 05:41 AM
17mm and 19mm for the engine and tranny bolts.
Joe
bd1308
Jun 7 2005, 06:03 AM
QUOTE (trekkor @ Jun 6 2005, 10:35 PM) |
You have the ten point allen CV bolt socket, right? 8mm, I think.
KT |
i agree about the rachet wrench...i have a 10mm for the dizzy bolt.....
I spent TWO days looking for the correct CV tool when my bolt turned out to be a 6mm hex bolt.
but the engine is hanging on 2 stands right now....in limbo
