Went to prep my car for the season moved it out of it's sleeping spot and there's at least a quart of oil on the floor
So I have it up on the lift trying to figure out where the oil is coming from, I thought it was the lower VC gasket, then thinking it could be the rocker chainbox Oring and I see this thing sticking out that I didn't recognize at first.
Gave it a push with my screwdriver it's a freaking loose rocker shaft!
So I went to pop off the VC and well fuch me I can't get the #2 bottom (twinplug) plug connector out past the suspension ear.
I could drop the engine just enough to clear, but to get that far I may as well just drop the engine right out. Besides now I want to check all of my rocker shafts, may as well do a valve adjustment, etc.
Sucks as I'm busier than hell on a dozen projects, several engines, including two high end 996 engine rebuilds.
Damn
