While restoring the heat/defrost/fan controls for my project car I knew that the
mechanism had a common issue.
The slide contacts for the three speed fan were melted. I had a good replacement contact piece and intended to just install it in my control panel..
What causes this failure ?
The problem at least partially, is because there is little or no detent feel when moving
the knob from one speed to the next. It is easy to make only partial contact which
causes overheated parts.
Why no detents ?
This is what I found. There is supposed to be a small ball under the leaf spring
of the arm in the second photo. As the arm is moved to the right side the ball is
pushed into the recesses in the grey bar under the arm. This is to provide
proper position for the fan contacts. No ball ? random contact position...
result ?..... melted contacts.
There is no ball in my panel.
Can someone supply the correct ball ?
I hope this long explanation is helpful, I haven't seen it covered.
