I'm getting to the point where I am gathering up all my hardware to be re-plated. I've tumbled a lot of pieces and then stripped old plating off with some muriatic acid and coated with WD-40 for storage until ready to plate.
I'm having a tough time finding someone who plates smaller jobs here in the Houston area. Most of the plating shops are geared towards the oil/gas industry and take on massive jobs. I've reached out to a couple of local restoration shops to see if they'd share their contacts but no luck so far. Does anyone know of any Houston area platers?
I also have a few questions I thought I'd ask you all...
- Is there any resource to check and know if something should be clear or yellow? Or are folks just doing what looks best?
- I'm assuming most everyone is running with zinc plating as cadmium is hard to come by?
- Do intricate parts like latch catch mechanisms need to be completely broken down or can they be plated with their rivets and such in tact?
- Is there a minimum amount of prep work I should be doing on these pieces before dropping them off? The smaller parts are easy to tumble but I don't have access to a blasting cabinet anymore for the larger bits.
