shane
Apr 12 2018, 07:11 AM
Hi, am rebuilding my pedal assembly and read a post saying if you use a roll pin it will fail pretty fast. What's everyone using? And what size? Thanks in advance
GeorgeRud
Apr 12 2018, 08:22 AM
I’d just use the original sized roll pin. If the size isn’t shown on the PET, I’d just order it through the dealer or Pelican Parts. If the rest of the pedal assembly is properly assembled (and lubricated?), there isn’t an issue with the roll pins failing prematurely.
bbrock
Apr 12 2018, 08:50 AM
I could be wrong but I think what has been said is that you want to use a spiral style roll pin like the original and not the split hollow tube style you would typically find at the local hardware store.
Bartlett 914
Apr 12 2018, 09:34 AM
QUOTE(bbrock @ Apr 12 2018, 09:50 AM)
I could be wrong but I think what has been said is that you want to use a spiral style roll pin like the original and now the split hollow tube style you would typically find at the local hardware store.
