80cap
Apr 20 2018, 02:28 PM
Ok, I set the valves to zero lash the engine has a very noticeable rattle. I think I read that they will sound like a bucket of bolts but I don't recall the sound level being this loud. I rechecked the clearance twice. The engine pulls real strong. I'm all ears!
Brian
iankarr
Apr 20 2018, 03:42 PM
shouldnt really sound like a bucket o bolts. do you have hydraulic lifters? If so, and it's been a while since the car was driven, it can sound really noisy till the lifters inflate with oil
80cap
Apr 20 2018, 04:29 PM
Solid lifters.
Brian
TheCabinetmaker
Apr 20 2018, 05:52 PM
Should sound very smooth. No rattles.
porschetub
Apr 20 2018, 06:08 PM
I don't understand zero lash with steel pushrods ,makes sense on a hyd lifter motor but on a solid tappet motor what happens when the engine heats up and expands width wise ?,surely the expansion rate would be different between steel and alloy pushrods ???.
I'am old but I never stop learning
Mueller
Apr 20 2018, 08:06 PM
Case ans heads are aluminium, they expand more than steel.
craig downs
Apr 20 2018, 08:09 PM
Check the clearance between the rockers and spacers. If it is a lot then that makes noise to.
wndsrfr
Apr 20 2018, 08:37 PM
QUOTE(Mueller @ Apr 20 2018, 06:06 PM)
Jake explains it that way....with lash at zero with engine cold it'll open up to .004-.006 with the engine hot, so you'll hear a bit of the usual ticking from the valves especially with thin oil....BP 20/50 may keep it a bit quieter...
nditiz1
Apr 21 2018, 06:29 AM
When should you use 0 valve lash vs the .006/.008?
80cap
Apr 21 2018, 06:50 AM
Only with chrome moly push rods.
I going to check again for a loose rocker today before cars and coffee.
Brian
Mark Henry
Apr 21 2018, 06:54 AM
Running .006 on steel PR will make them noisier.
They are noticeably noisier cold and you can still hear it warm, especially if you have a quiet exhaust.
